cost effective fuel gauge 24 valve
Old May 1, 2015 | 03:25 AM
cutthroatxxx's Avatar
cutthroatxxx
Default cost effective fuel gauge 24 valve
SOrry if not posted in the right section I have a 99 2500 long bed club cab 5 inch straight pipe, banks Egt & boost gauge fass hpfp fuel pump.I need a fuel gauge what is the most cost effective way to do this?
Old May 1, 2015 | 05:07 PM
What's wrong with the one in the tank? (that runs the dash gauge.)
Old May 2, 2015 | 12:02 AM
cutthroatxxx
I should clear that up its a fuel pressure gauge the 24 valves really need me 2 monitor the fuel system.
Old May 2, 2015 | 12:32 AM
horatio102's Avatar
horatio102
Stock fuel lines, or 1/2" hose?
Old May 2, 2015 | 12:50 AM
cutthroatxxx
For some reason my signature isn't showing up so...Fass hpfp, just discovered I had that lastnite, I have a banks turbo&bankd egt pillar gauges straight piped 5 in exhaust.33s 4:10s Was all on here when I bought it,I installed another time case & posi lok I do what else has been done to this truck it had a exhaust brake which was removed b4 I got it the vacuum port for it I'd still on there.I need to figure out if it has stock injectors because I don't think it does.
Old May 2, 2015 | 10:06 AM
Glowshift makes some pretty good stuff. I am sure there are others as well. Anything from 30 to 100+ PSI.
