Leak from what looks like the radiator. HELP
Old May 3, 2015 | 09:43 AM
Finn96's Avatar
Finn96
Default Leak from what looks like the radiator. HELP
So someone told me there was a little liquid on my parking spot the other day, so I put down some cardboard to find where it was coming from. It seems to be some hoses that come from the radiator. I'm not good with mechanics so I took some pictures in hopes of someone knowing what this is. My truck is a 2001 Ram 1500 offroad edition with the 5.9 in it. Any help is much appreciated. Thanks!
Old May 3, 2015 | 09:53 AM
Moparite's Avatar
Moparite
Looks like you have two leaks, the one in front of the radiator is an external transmission cooler. The other looks like a coolant leak. Was the water pump replaced recently? Check all the hoses to make sure they are tight.
Old May 3, 2015 | 11:07 AM
AtomicDog's Avatar
AtomicDog
If you find yourself having to replace the radiator and plan to keep the truck for the foreseeable future, see if you can find an all-aluminum radiator. The stock radiators have plastic tanks and aluminum cores, which tend to develop leaks over time. CSF 2969 is an all-aluminum bolt-in replacement.
Old May 3, 2015 | 01:40 PM
Finn96's Avatar
Finn96
It may have been when I last sent it to the shop... (Brakes redone, ball joints, wheel bearings) Although I'm having issues with the brakes and the steering
Hopefully it isn't too pricey of a fix, especially since I might have some transmission issues(Revs to about 2100 before it shifts)
