Wheel hub assembly failure
Old May 3, 2015 | 10:04 PM
bigearl's Avatar
bigearl
Default Wheel hub assembly failure
I changed out my hub assemblies on my 01 Dodge Ram 1500 2wd. My first mistake was getting them off ebay at a cheap price.. have since ordered Timkin hub assemblies. I only have 800 miles on these hubs and got grinding noise on drivers side. Spun the hub and sure enough it was growling so I pulled it off and saw that all the grease was pushed out of the bearing. They were torqued to specs (175lbs). Could this just be the result of going cheap (never again) or lighten up on the torque? Don't want to mess up the Timkins.
thanks, bigearl
Old May 3, 2015 | 10:17 PM
Ham Bone's Avatar
Ham Bone
Always torque them to spec. Not over or not under. It's likely the result of super cheap bearings.
Old May 3, 2015 | 10:29 PM
bigearl's Avatar
bigearl
I was thinking the same think but just needed another opinion. Thanks for the reply.
bigearl
Old May 4, 2015 | 07:52 AM
BigGreenRam's Avatar
BigGreenRam
There's no going cheap when it comes to suspension parts
Old May 4, 2015 | 09:28 AM
Moparite's Avatar
Moparite
What was torqued? I sure hope it wasn't the spindle nut!
Old May 4, 2015 | 09:47 AM
Ham Bone's Avatar
Ham Bone
Oh wait you have a 2wd. Oops.
I think the 01 has unitized bearings. In which case they are torqued like that.
However, if you have the old school rebuildable bearings you do not torque them like that.
Old May 4, 2015 | 12:44 PM
I think the rebuildable bearings went away in 2000, or so....
