Grinding noise coming from tranny / tcase
Old May 10, 2015 | 01:33 PM
Ehfisherman50's Avatar
Ehfisherman50
Default Grinding noise coming from tranny / tcase
Having a problem with 97 2500 5.7l 5 speed truck. If I put the truck in any gear and start to let out clutch it will move with the idle of the truck but as soon as I give it any gas something give out and you hear a grinding noise and the truck starts moving also shifting from gear to gear got hard as well
Old May 10, 2015 | 01:34 PM
Check fluid level in the trans first...... Might wanna drain some out, and see if anything rude comes out with it.
Is the t-case (if you have one...) firmly in 2wd?
