Cruise Control issues!?!
Old May 10, 2015 | 04:02 PM
COL's Avatar
COL
Default Cruise Control issues!?!
Anybody ever have an issue where ONLY WHEN you use the Cruise Control the RPM jumps around occassionally almost like the torque converter is locking and unlocking? Mine does and some days are worse than others, but it nearly always does it. I try to avoid using it because i don't want to do any harm to my transmission, but it sucks not having it because I do make long trips somewhat frequently.
Old May 10, 2015 | 05:36 PM
beeker's Avatar
beeker
When my torque converter failed it did exactly as you describe. It would bump up a couple hundred rpm and drop down. Did it only in cruise, rarely at first, then became more frequent until it wouldn't lockup at all. I dropped the trans and replaced TC and it's been working great.
Old May 10, 2015 | 09:13 PM
COL's Avatar
COL
That is not what I wanted to hear...lol I have been noticing that though, it used to only do it once in a blue moon, then maybe once every half hour of driving, then there was days it wouldnt do it at all, and now it seems like it does it all the time, but only in cruise, not at all when I use the pedal.
Old May 10, 2015 | 09:28 PM
Try replacing the throttle position sensor first. That can also give you those symptoms.
Old May 14, 2015 | 10:17 PM
mcmurdo64's Avatar
mcmurdo64
I would have to agree with HeyYou. That is exactly what my '01 was doing, changed the TPS and it has never had that problem again. Started off only once and a while, got to the point I wouldn't run cruise anymore because it was almost constant.
