New shock advise
Old May 11, 2015 | 04:21 PM
Sounds a lot like the weather here.....
Just measure up from the ground, to the lower edge of the wheel opening, directly above the center of the axle. (straight line, up from the ground, passing thru the hub.) Post that up, and we can compare it to known stock trucks.
Old May 11, 2015 | 04:40 PM
magicalninja1981's Avatar
magicalninja1981
Awesome! Front = about 40 1/2 Rear = About 43 1/2.
Old May 11, 2015 | 04:47 PM
Mine is 38 3/4 front, and 41 1/2 rear. Given that your tires give you two inches more height than mine..... I would say you are stock ride height. (and yes, it DOES look taller.... )
Old May 11, 2015 | 05:07 PM
magicalninja1981
Oh sweet! Thank you for the info!
Old May 11, 2015 | 05:09 PM
Bilstein 5100's.
Old May 12, 2015 | 09:19 PM
magicalninja1981
Yep! 5100's, I liked the yellow and blue shocks but the monotubes sounded best for my back... and like they'll handle going to the dunes better.
