1997 clutch/trans issue?
Old May 13, 2015 | 10:36 PM
iconracing's Avatar
iconracing
Default 1997 clutch/trans issue?
After a through search nothing found...
1997 ram 1500 5.2 nv3500 5 speed 4x4. 140K original clutch, trans engine ect.
Problem is when i hold in the clutch too long (more than 5 seconds) with the truck in first or reverse the pedal gets "kinda stuck" wont come back up and gets stuck in gear. I usually have to turn the truck off or it will buck and stall. To correct this problem i usually need to give alot of gas and not sit on the clutch. Kinda of a pita when trying to back up a boat.
The trans shifts flawlessly in every gear, engine runs excellent, and clutch grabs great with no problems.
Old May 13, 2015 | 10:53 PM
iconracing's Avatar
iconracing
Question is why is the pedal getting stuck on the floor? Therfore stuck in gear
Old May 14, 2015 | 07:40 AM
Is the pedal itself binding? What do you have to do to get it to come up?
Old May 15, 2015 | 09:41 PM
iconracing's Avatar
iconracing
Pedal is not binding up... i usuall have to turn the truck off and pump the clutch pedal up to get it back to normal.
Old May 16, 2015 | 09:56 AM
That's just weird...... might be time to start disassembling the system, and see if you can isolate the problem......
Old May 16, 2015 | 06:16 PM
iconracing's Avatar
iconracing
Any possible chance the clutch master cylinder/ slave assembly are bad?
Old May 16, 2015 | 06:17 PM
Either that, or something with the throwout bearing/clutch fork...... Might wanna pull the slave cylinder, and see what things look like down there.
Old May 16, 2015 | 06:55 PM
iconracing's Avatar
iconracing
Im guessing the throwout bearing is on its way out.... i can hear the bearing making noise in neutral.... anyways thanks for your help
Old May 16, 2015 | 08:48 PM
The pedal sticking down though *shouldn't* be caused by a failing t/o bearing..... maybe the pressure plate?
Old May 17, 2015 | 08:06 PM
iconracing's Avatar
iconracing
I will crack her open this week sometime and keep anyone interested posted...
