Help! Crooked Ball Joint damage, repalce axle now?
Old May 28, 2015 | 09:50 AM
Ham Bone's Avatar
Ham Bone
It's most likely in the steering column and the gear box. Pretty typical.
also, check pitman arm for slop.
Old May 28, 2015 | 12:05 PM
12-6 isn't going to be steering related. Probably bad hub/bearing.
Old May 28, 2015 | 06:17 PM
Ham Bone's Avatar
Ham Bone
I dont get what you mean by 12-6
Old May 29, 2015 | 08:28 AM
Moparite's Avatar
Moparite
Lift the wheel of the ground then put you hands on 12-6 o clock position and check for movement.
Old Mar 9, 2017 | 12:30 PM
George Karakatsanis's Avatar
George Karakatsanis
If you have a press, that is the best way. You can usually rent them from your local parts store. If it doesn't want to start square..... so long as it straightens out as it goes in, (which it really doesn't have much choice) all is good.
Guys this has been really helpful. My upper is going in crooked as well, I am concerned about cranking to hard on it but I see no way to straighten it out through the process.
Its getting a bit hard to crank, should I continue and it will just settle out?
Old Mar 9, 2017 | 12:47 PM
You might try putting the right size socket on it, and try and hammer it straight. Then put the press back on.
Welcome to DF!
Old Mar 9, 2017 | 09:41 PM
AtomicDog's Avatar
AtomicDog
I installed mine with a ball joint press and a 3/4" impact wrench. It takes a bit to press them in for sure.
Old Mar 10, 2017 | 01:29 PM
Mark S.'s Avatar
Mark S.
As shown in the OP's picture of the ball joint press, the lower surface of axle where the upper ball joint goes is not parallel with the upper surface. This causes the ball joint to **** as it is pressed in. If the ball joint starts to tilt, you need to stop and try pressing it off center a little bit ( I know its hard to do ). I think that some presses have an adapter that is slanted to solve this problem, or possible a custom on could be made.
