Torque converter
Old May 31, 2015 | 07:51 AM
Rage in the cage's Avatar
Rage in the cage
Default Torque converter
So I have this 96 Dodge Ram 1500 4x4 with the 5. 9. Just before is 200000 miles I decided on a facelift new hood new grill new tires hooked it up then all the sudden I started to feel a little bit of vibration in the gas pedal. Over the next couple days it started to get a lot worse engine vibrates shakes and once in awhile it'll throw a knock but it doesn't sound like a rod or a lifter, and it still has all its beasty powee. when you shut it off its got like a backspin to it and like a little wine but its not sounding like its from the motor. I pulled the inspection cover and all the bolts are tight. Has this ever happened to any one? Im believing it's the torque converter I've never dealt with a blown out torque converter befor are my suspicions right
Old Jun 2, 2015 | 10:04 AM
Does the trans shift OK? Cruise fairly nice? When do you get the vibration? Only in fourth gear?
Old Jun 2, 2015 | 12:51 PM
Moparite's Avatar
Moparite
New tires and it started, I would look there first. Where they balanced?
