codes p 0713 and p 1763
Old Jun 2, 2015 | 11:00 PM
eagle101's Avatar
eagle101
Default codes p 0713 and p 1763
My 2001 ram 1500 transmission 46're will go into what I thank is limp mode but will come back out if I let off the gas. It is showing codes p 0713 and p 1763. What could be causing this.
Old Jun 3, 2015 | 08:28 PM
Moved this to the correct section.
P0713 Trans Temp Sens Voltage Too Hi
P1763 Governor Press Sens Volts Too Hi
Probably a short in the harness. Check at the connector on the trans for bare wires and other such nonsense.
