thermostat sticking
Old Nov 1, 2005 | 05:40 PM
pastfast125's Avatar
pastfast125
Default thermostat sticking
I might be buying a new truck, and the guy said the thermostat is sticking, is this a problem to worry about? If so how much does it cost to replace or fix, and how difficult is it to do?
Old Nov 1, 2005 | 06:34 PM
steve05ram360's Avatar
steve05ram360
Default RE: thermostat sticking
t-stat's are easy to change... but you might want to bring it to a shop and have them check for a leaky head gasket. I'd guess that it's overheating, does it overheat when you 1st start it up? that could be a sign of a stuck t-stat... anything else, have it checked out 1st.
head gaskets are easy to change on the ram, just time consuming.
