2000 Ram sway bar end links
Old Jun 20, 2015 | 03:18 PM
70sixpkrt's Avatar
70sixpkrt
Default 2000 Ram sway bar end links
I need to replace my sway bar end links with some good ones on my 2000 Ram 1500 4x4. Is the Moog #K7453 the ones I need? Do I need to jack up the truck or can I change it with the wheels on the ground.
Old Jun 20, 2015 | 04:30 PM
You can change 'em with the wheels on the ground. Don't know if those are correct though, the website should tell you...... look at yours, look at these, look the same? Then they probably are.
