Exhaust smoke, dark; Towing Related Maybe
Old Jun 24, 2015 | 10:55 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
I stand corrected UU and HY. Thanks. Good to have "old" guys around.
Here we go.
DESCRIPTION - MODES OF OPERATION
As input signals to the Powertrain Control Module
(PCM) change, the PCM adjusts its response to the
output devices. For example, the PCM must calculate
different injector pulse width and ignition timing for
idle than it does for wide open throttle (WOT).
The PCM will operate in two different modes:
Open Loop and Closed Loop.
During Open Loop modes, the PCM receives input
signals and responds only according to preset PCM
programming. Input from the oxygen (O2S) sensors
is not monitored during Open Loop modes.
During Closed Loop modes, the PCM will monitor
the oxygen (O2S) sensors input. This input indicates
to the PCM whether or not the calculated injector
pulse width results in the ideal air-fuel ratio. This
ratio is 14.7 parts air-to-1 part fuel. By monitoring
the exhaust oxygen content through the O2S sensor,
the PCM can fine tune the injector pulse width. This
is done to achieve optimum fuel economy combined
with low emission engine performance.
The fuel injection system has the following modes
of operation:
˛ Ignition switch ON
˛ Engine start-up (crank)
˛ Engine warm-up
˛ Idle
˛ Cruise
˛ Acceleration
˛ Deceleration
˛ Wide open throttle (WOT)
˛ Ignition switch OFF
The ignition switch On, engine start-up (crank),
engine warm-up, acceleration, deceleration and wide
open throttle modes are Open Loop modes. The idle
and cruise modes, (with the engine at operating temperature)
are Closed Loop modes.
DECELERATION MODE
When the engine is at operating temperature, this
is an Open Loop mode. During hard deceleration, the
PCM receives the following inputs.
˛ Air conditioning select signal (if equipped)
˛ Air conditioning request signal (if equipped)
˛ Battery voltage
˛ Engine coolant temperature sensor
˛ Crankshaft position sensor
˛ Intake manifold air temperature sensor
˛ Manifold absolute pressure (MAP) sensor
˛ Throttle position sensor (TPS)
˛ Camshaft position sensor signal (in the distributor)
˛ Park/neutral switch (gear indicator signal—auto.
trans. only)
˛ Vehicle speed sensor
If the vehicle is under hard deceleration with the
proper rpm and closed throttle conditions, the PCM
will ignore the oxygen sensor input signal. The PCM
will enter a fuel cut-off strategy in which it will not
supply a ground to the injectors. If a hard deceleration
does not exist, the PCM will determine the
proper injector pulse width and continue injection.
Based on the above inputs, the PCM will adjust
engine idle speed through the idle air control (IAC)
motor.
The PCM adjusts ignition timing by turning the
ground path to the coil on and off.
I'm fairly sure the Tow Mode from the SC is not that complex.
Old Jun 24, 2015 | 11:47 AM
Here we go.
Suppose it depends on how much the changed the code. They don't re-write the whole thing, they just make alterations here and there.
Who you calling old?
Old Jun 24, 2015 | 06:12 PM
UnregisteredUser's Avatar
UnregisteredUser
Wonder if your tow tune doesn't completely cut off fuel.... or, if there is a bit of a flaw in the programming, that was feeding to much, hence, your black smoke.
I've got the same tuner and run the towing tune all the time, and decel mode works just fine for me. I see it a lot, living where I do.
Remember when that job was done by a vacuum actuated decel valve that was almost always failed after a few years? Pop pop pop pop pop pop pop...
