fuel filler neck replacement
Old Jul 5, 2015 | 08:10 AM
scotmick's Avatar
scotmick
Default fuel filler neck replacement
I have a 1998 ram 1500; I want to replace the fuel filler neck, which I have. I can access it OK, but I am leery of the connection of the rusted out pipe to the rubber hoses coming from the tank. I DO NOT want to damage the hoses and it is a limited space area to work in. I DO NOT want to remove the bed or the tank. I thought of soaking the connections with WD-40 and try to ease the pipes out of the hoses. Any suggestions?
Old Jul 5, 2015 | 10:44 AM
WD-40 is the wrong stuff for that. PB Blaster would work much better.
What you really need, is a booger picker. Makes hose removal MUCH easier, and doesn't damage the hose. (unless it is already so dry rotted, it needs to be replaced anyway.)
Old Jul 5, 2015 | 11:22 AM
scotmick's Avatar
scotmick
Default Booger picker.
Thanks; I'll try the Booger Picker, my neighbor has them. The hoses seem fine, it's just the rusted pipes now. Hopefully I can get it squared away.
Old Jul 6, 2015 | 11:55 AM
scotmick's Avatar
scotmick
Default Booger Picker. 1998 Ram 1500.
Thanks, the BP worked, along with several dousing of lubricants.
I have the main neck set up, but the overflow is a little tougher because the pipe broke inside the rubber hose to the tank. I cut off a piece of the hose and I am into the lube stage. I'll spray it a few times and in a few hours I should be home free. It's a pretty tight work area.
Thanks again.
Old Jul 6, 2015 | 12:21 PM
Could always just crush the hose that has the broken off pipe in it. The hose will get over it, the pipe will come out easier.
Old Jul 7, 2015 | 11:26 AM
scotmick's Avatar
scotmick
I'm not prepared to do that, yet.
