99 Dodge Ram 1500 wont shift into 4th gear
Old Jul 5, 2015 | 10:44 PM
Sparky86's Avatar
Sparky86
Default 99 Dodge Ram 1500 wont shift into 4th gear
Ok so I noticed my check engine light came on and I hooked up my engine scanner and it comes out with P0753. I googled it and it says shift solenoid A electrical. So I changed the wire harness for both solenoids under the pan. And still wont shift.
Old Jul 6, 2015 | 10:03 AM
Did you change the solenoid?
Old Jul 6, 2015 | 01:12 PM
Moparite's Avatar
Moparite
P0753 Trans 3-4 Shift Solenoid/Trans Relay Circuits
Check that the relay is good, change the solenoid and reset the pcm.
