a/c temperature control not working correctly
Old Nov 2, 2005 | 01:18 PM
quedogf94's Avatar
quedogf94
Default a/c temperature control not working correctly
The temperature control for my 2000 Ram does not work correctly, its either too cold or too hot. For example, when the a/c is on and I want to raise the temp b/c its too cold it does not work until I turn the **** into the red, then its too hot. In order to get cold air going through the vents again, I have to turn the **** to the coldest position. Has anyone had the same problems?
