Love my 01 Ram but i want more power. Engine swap?
Your built magnum motor is not pumping out 390hp/450tq. Wish you would have run on the dyno when it was finished. I think your probly closer to 300hp/350tq. Lets not make newer members think you can just bolt on heads and a cam and get 150hp bump.
Let's see if we can end this before a fight breaks out. No way the truck owner knows for sure without dynoing it. And there is definitely no way anyone else knows what his truck's HP numbers are by reading his post above.
No fights with me. I know what the truck can do, and I had merc225hp, who is a magnum motor god, play with a dyno program he has, and crank HP was right in the 390hp range with all the parts I had installed.
No I didn't put it on a dyno, because the dynos around here won't tune dodge motors, with SCT programmers.
When I get my Dakota and get the motor situated in it, I'm going to look at a few dyno shops in Massachusetts.
