can't find the miss
When I swapped in a 727 on my JTEC PCM POS controlled Magnum 360 in my Dakota R/T I had the "auto" flashed out of the PCM, since then I ditched the PCM and went with a carb, I got tired of the crap...
With the carb it runs better, faster and is deadly consistent at the track, something it never was with the PCM, even tuned by different people using a SCT.
With that said, double check all your wiring...And grounds. PCMs love grounds...not just grounds, but GOOD grounds.
You've got the correct flexplate/converter for the external balance, right? Not that I think that would cause your problem, but it won't help if it isn't.
If you can get it to mess up at idle, kill spark to one cylinder at a time and see if you can isolate which one(s) are missing.
You've checked compression and leakdown right?
