Brakes and Rotors an Calipers ?
Old Sep 3, 2015 | 07:36 PM
fj5gtx's Avatar
fj5gtx
You aren't running the engine while bleeding, are you? I always bleed with power assist. I'd bleed it again (sorry), and give us the results - hopefully that solves your problem.
Old Sep 3, 2015 | 08:10 PM
Khris1994's Avatar
Khris1994
Default Brakes and Rotors an Calipers ?
If it went down low enough the abs pump may need bleeding. That would be by computer if it is.
Old Sep 3, 2015 | 09:36 PM
Spillage's Avatar
Spillage
Does the fluid level drop?
Old Sep 3, 2015 | 09:40 PM
Old Dodge 1's Avatar
Old Dodge 1
How do you bleed the ABS pump, is it the service manual?
Old Sep 3, 2015 | 09:49 PM
Khris1994's Avatar
Khris1994
Requires a scanner with the capabilities
Old Sep 3, 2015 | 09:52 PM
Old Dodge 1
Thanks
Old Sep 4, 2015 | 11:45 AM
Old Dodge 1
No the fluid doesn't drop at all. I re-bled the brakes again last night three more times and it's doing the same thing. I got full panel when the trucks not running. The minute I start the truck the pedal goes to the floor so I'm assuming that it's that either the master cylinder or the power booster.i'm going to replace both of them tomorrow. Hopefully this will fix my problem.
Old Sep 4, 2015 | 10:47 PM
Spillage's Avatar
Spillage
Give us an update when done.
Old Sep 5, 2015 | 08:36 PM
Old Dodge 1
I have a really stupid question. if I put the calipers on backwards and the bleeder screw is on the bottom on both sides could that be trapping air in the system?
Old Sep 5, 2015 | 10:08 PM
fj5gtx's Avatar
fj5gtx
Originally Posted by old dodge 1
i have a really stupid question. If i put the calipers on backwards and the bleeder screw is on the bottom on both sides could that be trapping air in the system?
absolutely !
