01 2500 4x4 vents stuck in defrost mode
Old Sep 8, 2015 | 10:01 PM
r/tse's Avatar
r/tse
Default 01 2500 4x4 vents stuck in defrost mode
have vacuum @ hose going thru fire wall next to a/c, but no vacuum @ heat/ a/c / def. selector switch. any ideas? also what is the vacuum line going thru fire wall just under vent intake grille? both vacuum lines I am discussing are on passenger side.
Old Sep 8, 2015 | 11:02 PM
adukart's Avatar
adukart
Trace that line and visually inspect. Sounds like it is kinked/blocked/melted.
Old Sep 8, 2015 | 11:26 PM
r/tse's Avatar
r/tse
it disappears thru firewall how do inspect it what dissassembly would be required to access it?
Old Sep 9, 2015 | 07:36 AM
You will have to find out where iot comes out in the engine compartment. Usually lots of poking around with a telescoping mirror and a flashlight.
