96 ram 1500 fuel line issue
I am picking up a ram 1500 in a few days that I just bought today but it has a fuel leak it is the small rubber line that comes off the fuel pump don't know what size it is but need to find a cheap way to fix it just to get it home oreillys told me to put a brass coupler in with hose clamps but I need to know what size that line is or if you know a Easier way to fix it thanks and the line is like a cut not split but the cut is about 6-8 inches from the fuel pump
It is rubber line but are you talking about buying a brass coupler and hose clamps.also thank you for your response
i just replaced the fuel line today, used 5/16 nylon tubing with a 3/8 to 5/16 quick connect at the fuel pump. Ran tubing up rail and got a fuel line repair tube from napa 5/16 with the quick connect ferrule on both ends. used a quick connect 5/16 at end of nylon tube. quick connect end to repair fuel line . fuel line then runs to 5/16 connector at fuel line running up to engine. was quick and easy took bolts out of front of bed loosened rear 4 bolts jacked up bed was easy.
