Clunking when turning?
Old Sep 18, 2015 | 12:15 PM
  #21
Erik P's Avatar
Erik P
Got grease fittings? If you do, hit 'em all with a bit o' grease, and see if that changes the noise at all.
I greased the entire chassis about 3 days before I started having the noise...
Old Sep 18, 2015 | 11:51 PM
  #22
Erik P's Avatar
Erik P
****UPDATE - SUCCESS
Thanks for all the replies and help guys, really, truly appreciated.
Day 7 of me loosing my mind over this.
I crawled under the truck, had the girlfriend with the E-brake on, and the vehicle in drive, with wheels cranked to the lock, and a miracle happened, the truck clunked!!! clunked with me actually under the truck for once!!! i was below the T-case and from the moment it clunked, it was obvious it was right about me. I pry'd on all the body mounts, transfer case, everything, no luck, i grabbed my ratchet and started on the cross member bolts, and to my surprise they were slightly loose. they probably only loosened up to about 20 ft/lbs but i cranked on them. all four, and thats all it was. I am baffled at the fact that a slightly loose cross member would cause a loud clunk while turning, but it has clunked once since.
I am so happy and yet so relieved. Thanks again to the kind folks here at DF. right on guys.
Old Sep 19, 2015 | 10:39 AM
  #23
HeikIlm's Avatar
HeikIlm
Good thing you found the problem It's sometimes PITA to search reason for some strange noise.
