Throttle body stock bolt size?
Old Sep 19, 2015 | 08:36 AM
jrox44's Avatar
jrox44
Default Throttle body stock bolt size?
I have a 94 ram 1500 5.9L auto and I'm removing a spacer but I need to get stock bolts to remount the throttle body. The issue is no auto parts store carries them. Mine are too long with the spacer out. And I don't know how long I need with stock. And I can't pull a bolt and drive to the parts store to match it up to something. Does anyone know where I can order them or the exact size, thread, and pitch? It is recommended that they are replaced everytime they are removed do they have to offer them somewhere.
Old Sep 19, 2015 | 09:30 AM
Khris1994's Avatar
Khris1994
Replaced when removed? I reused mine. Grab some from a junkyard.
Old Sep 19, 2015 | 10:27 AM
HeikIlm's Avatar
HeikIlm
You could pull one out, measure the length and minus the spacer height.
I assume 5.2 has the same bolt, so here's the specs: length is 2.28" (58mm) and thread is UNC 5/16-18. There's a washer attached to a bolt, but if you can't find same kind of bolt, you can go with separate washer.
Old Sep 19, 2015 | 01:38 PM
jrox44's Avatar
jrox44
Do they really need replaced? I'm having a hard time finding the new bolts. I got 4 good ones from the junkyard. Why do they have to be replaced?
Old Sep 19, 2015 | 01:50 PM
Khris1994's Avatar
Khris1994
I've reused mine. If the junkyard ones are still solid than use them
