if u have a front end noise u cant figure out read this
Old Nov 3, 2005 | 09:39 PM
dodgebeater38's Avatar
dodgebeater38
Default if u have a front end noise u cant figure out read this
A wile ago i posted about haveing a front end noise i couldnt find. i changer everything in the front end but the diff gears and bearing and was about to change this untill i axidentaly saw the axle cut sheet on the dealers parts screen and saw that there was suposed to be a small plasting bushing in the pasenger side outer axle shaft was the end of the iner shaft rides. So if u have a front end noise u cant find check this bushing i changed everyting and spent all that money for nothing all i needed was this 6 dollar bushing hope this helps someone save sum cash and solve there problem cuz i wish i new it a month ago.
Old Aug 27, 2006 | 09:13 PM
apecx's Avatar
apecx
Default RE: if u have a front end noise u cant figure out read this
I have a 200 4x4 with a bad noise seems like the cv joint axle has play in it when I turn it near the pumpkin. Is the bushing in there? 104k miles
Old Aug 27, 2006 | 10:02 PM
The Burning Rom's Avatar
The Burning Rom
What year is your truck apecx? There are no CV joints on 2nd generation Rams. U-joints...but no CVs. CVs are found on 4wd trucks with independant front suspension (2002+ 1/2 tons).
Old Aug 28, 2006 | 03:46 PM
crazykidjj87's Avatar
crazykidjj87
i have a noise i cant figgure out...you hear it real bad when driving down a bumpy road and you can feel it in the passangers floor...tell me more about this bushing...is it hard to get at? and where exactly does it go?
