4x4 vaccum issues
Old Sep 15, 2015 | 09:30 PM
Austin25's Avatar
Austin25
Default 4x4 vaccum issues
I have a 98 dodge ram 1500 with the 5.9 in it and ive got a vaccum leak somewhere the front driveshaft will spin but no vaccum is going to the CAD to engage the front axle also i can hear a hissing noise at idle that will get slightly louder coming from the top of the motot but i cant seem to pinpoint its exact location any help would be appreciated
Old Sep 15, 2015 | 10:36 PM
Toward the rear of the motor, passenger side. That's where the bag o' snakes is. Peak around back there, and follow the line toward the back, and down to the t-case. They are the solid plastic lines, that like to get brittle, and break. Chances are good, one of your has done exactly that.
Old Sep 16, 2015 | 11:12 AM
Moparite's Avatar
Moparite
Check the metal lines that run along the frame also, If you have a leak/bad seal at the cad it will allow in moisture and rust the inside of the line. Mine was so rusted it blocked all vacuum to the cad. I love living in the rust belt. NOT!
