No dome light or headlight/ key buzzer
Old Dec 9, 2015 | 08:45 PM
Bwally1996's Avatar
Bwally1996
Originally Posted by dbbd1
Prob the CTM.
Ctm??
Old Dec 9, 2015 | 08:54 PM
dbbd1's Avatar
dbbd1
Central timer module.
Old Dec 9, 2015 | 10:20 PM
Bwally1996's Avatar
Bwally1996
Is that the relay kinda thing that is in the dash fuse panel that gets super hot? I wonder if that's whats causing my battery to die
Old Dec 9, 2015 | 10:38 PM
dbbd1's Avatar
dbbd1
No, it's behind the knee panel (under the steering wheel). There is a metal support on the right side, it's mounted to it (on the dude test you cannot see, facing the ashtray). Not sure what's getting hot at your fuse panel. Take a pic of it send post it.
Old Dec 9, 2015 | 11:49 PM
Bwally1996's Avatar
Bwally1996
Round timer module is what's getting hot. Round top left. The thing your talking about may be what's not plugged in on mine (8 pin plug hanging under my dash)
Old Dec 10, 2015 | 12:12 AM
dbbd1's Avatar
dbbd1
That's probably not it then. IIRC it is an 16 pin but I would have to check for sure (maybe tomorrow). And, I'll have to take a look at the round thing.
Old Dec 10, 2015 | 08:00 AM
96 doesn't have the CTM, that showed up on the 98 model year trucks.
Old Dec 10, 2015 | 12:31 PM
Bwally1996's Avatar
Bwally1996
Well shoot. I was hoping that would have been my fix
*UPDATE*
So I started pulling stuff today, there was no bulb in the ignition ring, clicky map lights do not have any kind of bulbs in them, dome light has a led bulb in it, got to lookiby at the bulb there is a slight possibility that the bulb was in there reversed (led only flows current one way) so maybe flipping it may cause it to come back on, but i kinda dropped it so I'll have to play around with it once I get a battery
Old Jan 17, 2016 | 10:07 PM
Bwally1996's Avatar
Bwally1996
Not sure if you've gotten your issue fixed or not, grab your door sensors, pull them straight out, unplug them and plug them back in, you could always check continuity on them or make a jumper
If your truck was purchased used the previous owner could have removed the buzzer, or it could be unplugged
Old Jan 24, 2016 | 12:36 AM
evilemokid94's Avatar
evilemokid94
I still don't have this fixed on mine, Iv got new door switches, new dome bulb and actually replaced the dome light wth one from the junkyard and still don't have a dome light. I have my key lights, my buzzer now, and all my other lights including radio but no dome.
