stutter/stammer at 1200 rpm
Old Oct 14, 2015 | 07:42 PM
rsmi4653's Avatar
rsmi4653
Post stutter/stammer at 1200 rpm
1998 Dodge Ram 1500 5.9 L stammers (almost sounds like a miss or vacuum leak) at 1200 rpm mostly after shifting to overdrive. I've read elsewhere that it could be torque converter problem and was told that distributor and rotor button might need to be changed. Any advice would be appreciated.
Old Oct 14, 2015 | 08:16 PM
Fixed your plenum yet? Check out the plenum sticky at the top of this forum.
Welcome to DF!
Old Oct 19, 2015 | 07:48 PM
rsmi4653's Avatar
rsmi4653
yes I have however will probably have to do it again. The young man that works on my truck says there is a kit that will be a permanent fix. I've ran better gas in my truck and it seems to have stopped the sputtering for now. I'm still not convinced it may not be the torque converter or perhaps just need to change distributor cap and rotor button.
Thanks for the reply
Old Oct 19, 2015 | 07:59 PM
Wouldn't hurt to have a look at the various ignition parts, if they haven't been changed in a while.
