So came out of the shop today from getting an oil leak checked, i bumped the curb and went over it, granted i have offroad suspension, so i didnt really think it would matter, it was an accident. Anyway went to make a u turn and while accelerating it literally just died right there in the middle of an intersection. Turned back on fine and went to go and the power cut out as i was accelerating and then a gassed it again and i was off. Periodically did this as i went home but never stalled. Then i went up my hill, and it crapped itself and kept loosing power and regaining, almost like stop and go a few times then it was good. Finally made it up my hill and pulled in my driveway and put it in park and it "literally" just died like it keeled over at the end of a marathon. Started it up a few times and it continued to die right as it turned over. Did it again, and gave it some gas and it stayed on fine and now im here. I don't have any clue wtf its doing.
researching online seems it might be a bad tps or iac, there both stock and cheap so i might just throw new ones in and see if shes fine again. Beforehand i might try reinserting the harnesses into the current parts.
sounds like a similar prob i was having. Replaced my TPS, but it was like $500 plus, wondering if i got ripped off. The issue was solved so it was worth it.
$500 to replace a TPS? Yes, you got ripped off. Lol
