Please help!! Possible bad front diff
Old Nov 13, 2015 | 05:15 PM
Brian Mckenna's Avatar
Brian Mckenna
Default Please help!! Possible bad front diff
Hello all. Glad to become a part of the community even with the horrible circumstances. I think my front diff may be bad. I have no 4wd. It is not the cad system I know that for sure the ring and pinon gears are fine also I think the splines are fine going into the diff. Also diff makes no noise. But at this point I'm at loss.
Old Nov 14, 2015 | 10:12 AM
What year is your truck?
Old Nov 14, 2015 | 10:20 AM
Brian Mckenna
Old Nov 14, 2015 | 10:30 AM
Then you should still have the CAD system. Check the passenger side axle tube. It'll be obvious if it is there or not.
Old Nov 14, 2015 | 08:00 PM
Brian Mckenna
I stated in the first post that it is not the cad system at all. I manually splined the two shafts together and spun the driveshaft and there was no movement at the wheels
Old Nov 15, 2015 | 11:00 PM
Ok, need to include those details when you post, as we have no way of knowing what you did.
I suspect that the collar did not stay engaged.
With the front jacked up, turn the passenger side tire, does anything else turn?
