charging system
Old Nov 23, 2015 | 01:19 PM
cjjournet's Avatar
cjjournet
Default charging system
Hey I am new to this .I just change my engine in my 2000 dodge ram 15004x4 5.9 I leave to go to work the next morning and my light are dem .a mile down the road my components shut off .so I swing back home .off the the top of my head I thought it was my alternator. Cuz I got a new battery. Still the same problems .they tell me its my (pcm).but on my voltage regulator I have a green.&a white blue wire that doesn't connect to anything. I am nervous about changing my (pcm)and that's not the problem
Old Nov 24, 2015 | 10:05 AM
Voltage regulator is internal to the PCM. (not chryslers brightest idea.....) What does the volt gage have to say? Had the alternator tested?
Old Nov 24, 2015 | 10:22 AM
cjjournet's Avatar
cjjournet
I took the new one to get tested and it came back OK .but once I start it the voltage gauge doesn't move at all
Old Nov 24, 2015 | 10:42 AM
What's the alternator output when the engine is running?
Old Nov 24, 2015 | 11:47 AM
cjjournet's Avatar
cjjournet
I think I was running off the battery because the alternator wouldn't kick on
Old Nov 24, 2015 | 02:14 PM
dbbd1's Avatar
dbbd1
Huh? Your alternator is always "on" when the engine is running.
Old Nov 24, 2015 | 03:45 PM
This ^^. Your alternator is always "on" if the engine is running and the belt is turning the pulley. Put a meter on your battery posts with the engine running. What is the voltage?
Old Nov 24, 2015 | 06:27 PM
Moparite's Avatar
Moparite
Might want to check the fuse in the distribution box in the engine compartment. I believe it's a 120 amp fuse.
Old Nov 24, 2015 | 07:40 PM
cjjournet's Avatar
cjjournet
I didn't have the time to mess with it so I brought it to the shop .we still trans find out what's up with the white blu(wb) and green wire from the voltage regulator. Or did my old alternator burn out my pcm
Old Nov 25, 2015 | 11:02 AM
Voltage regulators fail. It's an electronic part.... nothing new under the sun there. The fact that it is part of the PCM just makes it a MUCH more expensive fix.
