Disc Rotor Hub Assy.
Old Nov 24, 2015 | 12:59 PM
Mark S.'s Avatar
Mark S.
Default Disc Rotor Hub Assy.
It is time to do some front end work on my 96 Dodge 4WD 2500. I need to replace the original front disc brake rotors and the wheel bearings. I have been searching for a complete assy. rather than a separate rotor and bearing unit. I am trying to avoid the pressing of studs and the machining of rotors. Does anyone know of a supplier for the assembled unit. I realize that shipping may also be problem due the weight.
Old Nov 24, 2015 | 09:19 PM
Check rock auto.
Old Nov 25, 2015 | 10:59 AM
I don't think you can even find them per-assembled..... The front brake rotors on the 96 trucks are a pain, in later years, the rotors were slip-fit over the lugs..... wonder if it's possible to covert to the newer design........
Old Nov 25, 2015 | 10:46 PM
horatio102's Avatar
horatio102
Anything is possible...
Old Nov 26, 2015 | 01:11 PM
getdown78's Avatar
getdown78
A good air hammer eliminates the need of a press !
