Soooooo...my truck eats batteries
Old Dec 3, 2015 | 01:17 AM
Bwally1996's Avatar
Bwally1996
Default Soooooo...my truck eats batteries
When my last battery died, I didn't have the money to replace it, pulled the battery from the explorer which was starting and everything, let my truck sit roughly 32 hours mom needed the explorer I popped the battery back in, nothing no lights no nothing. What is causing my truck to kill batteries. My interior lights don't work so I don't think it has to deal with that, nothing was left on, there's nothing plugged into the power port
Old Dec 3, 2015 | 09:49 AM
Need to put a meter on it, and see if there is a draw with everything off. If there is, start pulling fuses till the draw goes away. Some things will always draw a bit of power, PCM, and Radio spring immediately to mind, but, that should be REALLY minor.
Old Dec 3, 2015 | 12:24 PM
ramsportrocks's Avatar
ramsportrocks
exactly what I was going to suggest.. aftermarket radio?? if so unplug it could be wired wrong and the cause of your constant drain and blown interior lights
Old Dec 3, 2015 | 01:26 PM
Bwally1996's Avatar
Bwally1996
Stock radio. What about a bad diode
Old Dec 3, 2015 | 04:29 PM
Bwally1996's Avatar
Bwally1996
How do I post pictures I'm going through the wiring under the dash and have found some stuff lol
Old Dec 3, 2015 | 09:18 PM
Host them someplace else, like photobucket, or similar. Then just use the image tags to imbed them in your post.
Old Dec 3, 2015 | 10:02 PM
Bwally1996's Avatar
Bwally1996
Not sure how to post pictures from mobile so I'm using drob box links sorry..
So I started pulling stuff inside today. Found I do have a bulb in the center light,
https://www.dropbox.com/s/6b7ek6czwc...8192.jpeg?dl=0. I thought there wasn't one now I have to find out why it don't come on
So I go ahead and pull off the overhead console and found out it don't have any bulbs in it
https://www.dropbox.com/s/l0muvcyh67...8175.jpeg?dl=0
Why is the connector so big? Like why only 3 wires. What are the other spots for?
https://www.dropbox.com/s/egyudtdn1w...4838.jpeg?dl=0
The wiring above it I can't tell if it has been screwwed with or not
https://www.dropbox.com/s/00ttrhs3bw...1511.jpeg?dl=0
So I move down and pull the kick panel off, first thing I see is this bundle of wires
https://www.dropbox.com/s/m1uciltes9...8181.jpeg?dl=0
Following these wires
https://www.dropbox.com/s/k3zcsk9h3p...4851.jpeg?dl=0
And they go out the firewall
https://www.dropbox.com/s/2miaxz6ocy...8185.jpeg?dl=0
Along with the skinny blue wire but that was to the previous owners switch for the kc lights I disconnected
The blue and black wires connect to the fuse block
https://www.dropbox.com/s/d0vsn8qxb0...8182.jpeg?dl=0
And go under the truck all the way back to a trailer connector
https://www.dropbox.com/s/afkqlzhb58...4850.jpeg?dl=0
https://www.dropbox.com/s/i3wf2dfkko...1523.jpeg?dl=0
Seeing how everything done is done crappy I disconnected the wires from the fuse block, took all the wires out from under the truck, clipped them from the trailer connector and removed the crapola from under the dash so that don't short anything out
I did manage to find a connector that isn't plugged into anything just dangling under the dash
https://www.dropbox.com/s/kz44h7reqi...1512.jpeg?dl=0
Does anyone know what it goes to???
While checking the fuses, up closer to the top what is that? The shiny fuse thing lol and it looks like there's supposed to be another one? Am I missing something important?
https://www.dropbox.com/s/aidsx4x0w5...8191.jpeg?dl=0
Old Dec 3, 2015 | 10:08 PM
Open a photobucket account, and host pics there. Dropbox apparently doesn't allow direct links.
Old Dec 3, 2015 | 10:12 PM
Bwally1996's Avatar
Bwally1996
I can click on the links I just posted and it opens another tab and shows the picture on my tablet. Did you click them?
Old Dec 3, 2015 | 10:27 PM
Yeah, and the pics do show up, eventually....... for some odd reason, they are REALLY slow to load for me. (15mb/s connection)
