Wet floor when it rains
Old Feb 4, 2016 | 09:25 AM
  #21
Keep us updated on this please. I am real curious if it is really fixed.....
Old Feb 4, 2016 | 10:23 AM
  #22
dbbd1's Avatar
dbbd1
I wonder if they meant and/or the rubber seals on the door and cab where the wires enter the door/truck cab.
Old Feb 4, 2016 | 11:15 AM
  #23
hdbiker1's Avatar
hdbiker1
When I went in before they were done, they had the int door panel off. That's when they explained what was going on, so no not where the wiring to the door enters the door or cab.
Old Feb 9, 2016 | 07:39 PM
  #24
Jylee968's Avatar
Jylee968
Do you have sliding rear glass, water can leak from the rubber channel into the left side. I seal the glass shut. No more lea.
Old Feb 10, 2016 | 10:45 PM
  #25
hdbiker1's Avatar
hdbiker1
I was told they ran water over the whole cab. Third brake light, clearance lights, windshield, door windows and rear slider. Anyway, it hasn't rained much lately, but so far no leaks.
I did read, a while back that someone had basically the same happen to them. The vapor seal had a fold in it along the bottom, which let water run into the cab between the door and the panel.
