Transmission reliability mods
Old Dec 9, 2015 | 07:10 PM
Bwally1996's Avatar
Bwally1996
Originally Posted by dapepper9
No difference between gas and diesel because diesel don't use 46re. Are you asking about pans or coolers?
Seen a couple places advertising the 46re for gas and diesel but the diesel cost more. I was asking about transmissions if the diesel one would be stronger behind the gas engine wouldn't it be better?
Old Dec 9, 2015 | 07:17 PM
dapepper9's Avatar
dapepper9
46re (v8) won't bolt up to a cummins (47re) and vice versa. Non-interchangeable. The pans are though.
Old Dec 9, 2015 | 07:36 PM
Bwally1996's Avatar
Bwally1996
Lots of weird false info out there on the interwebs. Lmao. If I'm gonna get a new pan I will probably have it tapped. Mine I think is dented
Old Dec 10, 2015 | 02:56 AM
zildjian3707's Avatar
zildjian3707
borg warner solenoid is hit and miss, i just put one in this time around and i still got the governor code back within a few months. wishing i had gone with the GM unit now. anyone have a link for that specific solenoid.
Old Dec 10, 2015 | 07:58 AM
There is a conversion kit available from WITTRANS.com. Third one down, if the link works right.
Old Dec 10, 2015 | 09:00 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Go with Borg Warner bands, which are much thicker than the stock MOPAR bands.
Old Dec 10, 2015 | 09:36 AM
dapepper9's Avatar
dapepper9
Prob something else then. Governor solenoid takes readings of pressure and if you have clogging in the valvebody causing pressure misreadings it will throw a code and a new one will not help. The BorgWarner is much more reliable than jerryrigging the GM in
Old Dec 10, 2015 | 10:19 AM
dbbd1's Avatar
dbbd1
Here you go...
http://www.dnjcomponents.com/index-2.html
Old Dec 10, 2015 | 12:26 PM
Bwally1996's Avatar
Bwally1996
Link acted weird on mobile. So when I change the filter, swap to at least the borg Warner? You know, most of my fun stuff has been bw stuff, the turbo on the eclipse, the transmission for the 280zx. Ahh borg Warner parts just last
Old Dec 10, 2015 | 05:50 PM
Yeah, it's a LOT cheaper than the GM conversion. (216.00 bucks for that......)
