replacemenet seat cushions
Old Dec 11, 2015 | 05:14 PM
husbandhas97dodge's Avatar
husbandhas97dodge
Default replacemenet seat cushions
I am trying to find replacement cushions for my husband's 1997 dodge for a Christmas gift and want it to be a surprise. I called the dealership and they don't sell the cushions anymore. Tried searching online, but am not having any luck. Does anyone have any suggestions? Thanks for your help!
Old Dec 11, 2015 | 05:40 PM
Nate_rs's Avatar
Nate_rs
I need one for my drivers seat because all the wires that hold the cushion up broke and the seat sags real bad. Only thing I know to do is head to the junkyard and grab a good condition seat out of another Ram.
Old Dec 11, 2015 | 05:45 PM
husbandhas97dodge
I thought about a junkyard, but all the friends I asked said it was probably a long shot... I guess I'll have to try that!
Old Dec 11, 2015 | 06:24 PM
UnregisteredUser's Avatar
UnregisteredUser
Getcha some suitable springs and some tie wire from the hardware store and you can fix the thing up for cheap in less than an hour. When I did it, I put a very thin piece of plywood (essentially paneling) between the wire and foam to prevent erosion of the foam. Works great.
Old Dec 11, 2015 | 06:30 PM
UnregisteredUser
Try eBay. There are always several sellers with the foam itself, and usually a few with complete cushions. I don't know if he's still around, but there used to be a seller there who'd rebuild the things for a pretty reasonable price.
Old Dec 12, 2015 | 12:06 AM
Nate_rs's Avatar
Nate_rs
Just checked eBay and found a couple but they were $100+ used and stained so I'm gonna be going to my local junkyard where I can get a seat I like for $30
Old Dec 12, 2015 | 01:16 AM
J415's Avatar
J415
Maybe craigslist? Someone parting out there ram might be able to help you.
Old Dec 12, 2015 | 04:13 AM
Ram Driver's Avatar
Ram Driver
I went through this problem when I got my truck, the driver seat lower cushion was shredded and beyond repair. I went to pic n pull and every driver seat with the material pattern I needed was the same way, or worse. But, all of the passenger seats cushions were in perfect condition. So, I bought a passenger seat cushion and bolted it in place of the shredded driver seat cushion. They are pretty much the same cushion, with just very minor differences. The main difference is the vinyl on the edge of the seat that is normally on the inside and not seen, will be to the outside when bolted to the driver seat frame, which really isn`t a big deal.
Old Apr 23, 2016 | 02:41 PM
dbbd1's Avatar
dbbd1
I just found these...
(am I the first to find out about these, or the last?)
http://www.ebay.com/itm/1999-2000-20...JW9p9d&vxp=mtr
Old Apr 23, 2016 | 04:51 PM
Jimythefan's Avatar
Jimythefan
First time I've seen those, and I check ebay periodically just for cushions. I have one of their bottom leather seat covers, guess I'll have to get one of those too.
Thanks for that link!
