IAC and MAP
Old Dec 28, 2015 | 07:47 PM
Khris1994's Avatar
Khris1994
Default IAC and MAP
Went to the stealer today to look into getting IAC and MAP sensors as the truck is lousy starting and I believe the IAC is going. And figured the map is original so I'd change that. IAC 160$ but not in stock. MAP 120$... That just seems like a ripoff so I didn't buy. Anywhere that sells OEM parts cheaper?
Old Dec 28, 2015 | 09:41 PM
jsmith1969's Avatar
jsmith1969
Yep, ebay has a couple Mopar dealers that are cheaper than getting them in person at the dealer.
Here's one of them I've bought a few parts from http://www.ebay.com/usr/stevewhitemo...p2047675.l2559
Just checked he didn't have iac so here's one http://www.ebay.com/itm/Dodge-Ram-Tr...JR-qXK&vxp=mtr
Old Dec 28, 2015 | 10:17 PM
Khris1994's Avatar
Khris1994
this should work?
Old Dec 29, 2015 | 12:52 AM
zildjian3707's Avatar
zildjian3707
i bought a new iac for 30 bucks at the local auto store and it works flawlessly
Old Dec 29, 2015 | 09:54 AM
jsmith1969's Avatar
jsmith1969
Originally Posted by Khris1994
this should work?
Yep it should
Old Dec 29, 2015 | 09:58 AM
jsmith1969's Avatar
jsmith1969
I've had bad luck with non-Mopar parts myself, spent a couple weeks trying to figure out fluctuating idle because I had a new non-oem TPS so had ruled that out. Finally listened to a couple guys and bought a Mopar one and it fixed the problem.
So yea you may get lucky but personally I'm not taking the chance anymore.
Old Dec 29, 2015 | 11:50 AM
Moparite's Avatar
Moparite
You can use Delphi parts, Thay are an oem manufacture to the auto makers. It's possible the oem parts are made by them. The crap you get at the local parts store is not!
Old Dec 29, 2015 | 01:35 PM
dapepper9's Avatar
dapepper9
Get the mopar part number and search it on Amazon.
Old Dec 29, 2015 | 07:23 PM
Spillage's Avatar
Spillage
That's the way to do it....
Old Dec 29, 2015 | 10:15 PM
2bit's Avatar
2bit
Standard Motor Products makes parts for the OEM's also. I buy them online from Rock Auto.
