horn
Old Jan 2, 2016 | 12:40 PM
horace's Avatar
horace
Default horn
The horns on my old Laramie are just sick sounding, the shiny pickup's horns have just quit working. Ideas?
Old Jan 2, 2016 | 12:46 PM
dbbd1's Avatar
dbbd1
Wolo mini air horn.
Old Jan 2, 2016 | 01:06 PM
dbbd1's Avatar
dbbd1
This one...
http://smile.amazon.com/gp/product/B...=sr_1_2&sr=8-2
Old Jan 2, 2016 | 05:19 PM
UnregisteredUser's Avatar
UnregisteredUser
The Stebel Compact Nautilus, which I'm running, seems to be the same unit as the Wolo but with fewer cute stickers affixed to the Compact Nautilus. It moves the deer and elk off of the highway just fine so far, and I'm thinking of adding a second one to see if it makes for more pellets on the highway when they skedaddle. I also tested it on a few aggressive drivers in Las Vegas, and it made the desired impression upon them, too.
I've got mine tucked up behind the bumper, with an L bracket bolted into an existing hole in the lower crossmember (in front of the radiator) which I tapped. I snagged the relay coil power with a parasitic tap on the stock horn wiring, leaving the stock horns connected, and brought power to the Nautilus relay contacts directly from the battery with an inline fuse holder on the B+ side. Installation, including wrapping the wiring up in flex conduit and routing and anchoring it nicely, took about half an hour.
Old Jan 4, 2016 | 02:58 PM
Sheriff420's Avatar
Sheriff420
Most of the cheap air horns are too high pitched for me. I got some horns from a couple mid-90's Cadillacs from a junk yard for $10. I hooked the horns up to a relay and the stock horn wires activate the relay. The horns I have are four different notes so there's a good blend of high and low pitch. I had to make a bracket out of some scrap metal to mount them but that was pretty easy since there were already threaded holes in the engine compartment just waiting for something to be put there.
You can see the old air horns below them that sucked because the were really high pitched.
Old Jan 4, 2016 | 04:19 PM
horace's Avatar
horace
Are any of these remedies just plug & go. My 50 Coronet will wake up the dead! I need easy & louder
Old Jan 4, 2016 | 04:47 PM
dbbd1's Avatar
dbbd1
I disconnected my 2 stock horns and spliced on 2 spade connectors for the new wolo one. No additional relays, same fuse size.
