Cb trc-483
Old Jan 5, 2016 | 03:18 AM
Deliverance1985's Avatar
Deliverance1985
Originally Posted by jsmith1969
You'll need a swr meter to tune it also
Oh and I don't go through drive through or anything like that. That ****s worse than red meat for ya. And I like my game meat still fighting and bleeding when I eat it. ....I got a meter. So there were only two places I could go . Since I wasn't south I went north . Guy set me up with a hood bracket a 4ft blue firestik. Coax cable and the meter kit. Don't like the two eye prongs on the coax since the wiring is slightly exposed . Some electric tape will fix it up . But I'll load pics in the am daylight. Anyway got the bracket and atenna installed and ran the coax . No drilling necessary. And was able to run it under the carpet and up under the drivers seat to the middle seat. So the cable was just the right length. Not bad for a 6ft cable. Have to buy some wire the wiring for the CB isn't long enough for where I want to install it and that I have to run it up under the carpet and through the fire wall. Everywhere I've read says battery is the best connection. 👍 I'll load pics tommorrow . Should be fully set up and operational after that.
Old Jan 6, 2016 | 01:46 AM
Deliverance1985
ok so it's dark and I was dinking around with it. There was a bracket under the middle front seat so I put it in there but it moves around to much for my liking. So now back out to unlistenable the middle seat and put the CB under that bracket. Since I didn't have any holder I believe this will be best and the CB buttons will be in reach instead of trying to reach under the seat. I was thinking outta sight outta mind but that's not gunna work 🙃
