Need help with brake problems.... Hoping for fast replies
Old Jan 6, 2016 | 11:22 AM
Ham Bone's Avatar
Ham Bone
Do people really flush their brake fluid every two years??
Old Jan 6, 2016 | 01:37 PM
hdbiker1's Avatar
hdbiker1
Have you had the brakes bled?
Old Jan 6, 2016 | 02:20 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Strangely enough, people change their oil from 3,000 - 15,000 intervals. Why should other maintenance be ignored?
Old Jan 6, 2016 | 04:44 PM
RyleDup0766's Avatar
RyleDup0766
So i replaced the abs sensor in the pumpkin, And still have the problem. I pulled the rear diff cover off, and inspected everything inside. No chipped or damaged teeth. ABS ring looks perfect. As of now I have the ABS fuse pulled out so I can drive it and stop safely. Could it be the abs motor itself? Not really sure what else could cause the problem. As i said in my first post... If im stopping for a stop sign or light, at 25 mph and under the abs motor kicks in and feels like im sliding on ice while stopping...
And I told him he needs to replace the flex lines, so he is going to do that
Any other ideas???
Old Jan 6, 2016 | 04:51 PM
Well, if you just want to throw money at it, replace both front wheel speed sensors as well.
Old Jan 6, 2016 | 06:12 PM
Ham Bone's Avatar
Ham Bone
Replace the flex line first.
Old Jan 6, 2016 | 06:57 PM
UnregisteredUser's Avatar
UnregisteredUser
"He Saved A Few Bucks On Brake Fluid" would be a very unflattering epitaph, so I bleed my brakes every Spring after they've taken up the winter's water, and every second year it's a full flush bleed. My wife's really glad that I bought a power bleeder so she's not stuck doing its job any more.
Old Jan 6, 2016 | 07:03 PM
RyleDup0766
I told him to replace replace both flex lines, he said hes going to order them
Any other ideas?
Old Jan 6, 2016 | 07:04 PM
RyleDup0766
The sensor for the rear was only $12, so we tried that. Next is going to be the flex lines
Old Jan 6, 2016 | 08:43 PM
Moparite's Avatar
Moparite
Are the brake and abs lights on? If so it set a fault code. If you can get it (i believe you have to ground out a terminal on the obd port for your year) it would give you a better idea of what is going on with abs.
