Burping the cooling system (specifically the heater core)
Old Jan 20, 2016 | 11:57 AM
Moparite's Avatar
Moparite
NONE of this is necessary if you drill a hole in the t-stat! Do it and forget about it. I have had the coolant out of the system plenty of times with not one issue. Only thing is it will take a while to fill it because you have to wail for the air to go past the t-stat(hole) then fill with fluid. Done, Drive it with heat! A lot of t-stats have a small valve(air bleed in pic) to do this but i haven't seen one for the 5.2 5.9's.
This t stat is for a different motor but you get the idea.
Old Jan 20, 2016 | 12:10 PM
Ham Bone's Avatar
Ham Bone
My t stat has that air bleed.
Old Jan 20, 2016 | 07:40 PM
2bit's Avatar
2bit
I agree with the hole in the thermostat. Extending the hose will work,but isn't necessary with a bleed hole in the Tstat.
Old Jan 20, 2016 | 08:04 PM
dbbd1's Avatar
dbbd1
^ X2
If you are replacing the thermostat (or simply "in there"), this is the easiest way to handle the issue.
