Looking for a transfer case
Old Jan 19, 2016 | 07:52 PM
madmax0r's Avatar
madmax0r
Default Looking for a transfer case
Hello,
My transfer case recently started making a fair amount of noise.
I'm either in the market for a new one, or would like advice as far as rebuilding one.
Thanks in advance
-Buck
Old Jan 19, 2016 | 07:56 PM
Drop the rear drive shaft, pull the tailhousing off the t-case, and see if the snap-ring abandoned shaft...... Fairly standard failure.
Old Jan 19, 2016 | 08:15 PM
madmax0r's Avatar
madmax0r
Ah,
That's super convenient. I was going to put some new U joints on anyway.. They don't seem terrible, but I figured I would rule them out as an additional producer of noise.
Many Thanks!
Old Jan 19, 2016 | 09:17 PM
madmax0r's Avatar
madmax0r
quick question,
What is the easiest way to know if you have a np231 np241 or np243? Do you know off the top of your head? I'm ordering the transfer case saver to be installed regardless of the c clip's status...
If the transfer case is already making noise, is it likely too late for the saver to be of any good?
2001 offroad sport 150k miles 5.9L 46re trans
thanks again
Old Jan 19, 2016 | 10:47 PM
There is a tag on the back side of the t-case. It's round, metal, and should have a red checkered pattern around the edge, or some such. It will have the t-case model number stamped on it. Chances are real good you have an NP231D though. (that's what came stock)
