2001 dodge ram no power under heavy acceleration
Old Jan 21, 2016 | 10:44 AM
malibuman's Avatar
malibuman
Default 2001 dodge ram no power under heavy acceleration
I have a 2001 ram 1500 4x4. about a month ago it started loosing power under acceleration. When I step on accelerator the rpms go to 3000 and then start to reduce the longer I hold the pedal. this happens in drive as well as in neutral. If I drive down the road it will do fine all the way to 75mph but if I push it and really step on the throttle to go up hill or just to try getting to speed faster forget it. I have read some of the posts and have already replaced cat and both o2 sensors. looking in the throttle body really not that dirty. one thing I have noticed while having scan tool hooked up is the spark advance will increase normally to 40 degrees then when I stomp the pedal it drops to 15 or lower. I think it should stay advanced but not shure. need help
Old Jan 21, 2016 | 12:49 PM
hdbiker1's Avatar
hdbiker1
I'd check your cat. Had a similar problem with a jeep. Would go down the road fine until I would encounter a hill, then it's slowly lose speed even with the throttle to the floor.
Old Jan 21, 2016 | 02:37 PM
This.
Usually a result of a blown plenum. (see the stickied thread at the top of this forum.)
Old Jan 21, 2016 | 03:39 PM
malibuman's Avatar
malibuman
thanks. not sure where this stickied thread is.
Old Jan 21, 2016 | 04:42 PM
malibuman's Avatar
malibuman
Hey you
I'm new to all of this. not sure exactly what you mean by stickied thread. Can you help
Old Jan 21, 2016 | 06:19 PM
Stickied threads are always at the top of the forum. They are 'stuck' there. (pinned is another term that is used.) You are looking for the "be-all, end-all, plenum thread. Most of the pertinent information is in the first couple pages, but, all of it is a good read. (over 80 pages.......)
