do these come with solid axles?
Old Mar 14, 2016 | 11:55 AM
  #21
Nate_rs's Avatar
Nate_rs
Originally Posted by William Chaple
sweet! is this everything I need? Im really glad you provided the links! this helps a lot!
You'll also probably either need to re-index your transfer case or get a new front driveshaft. The stocker is gonna be pretty maxed out with that much lift.
Extended brake lines would also be a good idea. Russell make some pretty nice steel braided ones. You can find them for under a hundred bucks.
The p/n is 694550
