How long does it take to actually remove a 5.9?
Old Jan 27, 2016 | 04:30 PM
evilemokid94's Avatar
evilemokid94
Default How long does it take to actually remove a 5.9?
Iv been tossing the idea around a out looking and buying a stock 5.9 for my 99 ram. The point of me buying one is to go ahead and rebuild it and add on a few bolt ons. But I'm curious as how long it takes to actually pull the motor? I can do an older chevy in around 2 hours but haven't messed with anything this new as far as pulling the motor.
Old Jan 27, 2016 | 04:44 PM
The process is pretty much the same.... disconnect all electrical, torque converter bolts, bellhousing bolts, exhaust, power steering (either the lines, or, the whole bracket and pump) a few vacuum lines, loosen the engine mount bolts (no need to completely remove them) and out it comes. If you are in reasonable health, have a clue, (which you apparently do. ), and things 'go well'..... 2 to 3 hours is a reasonable guesstimate.
Old Jan 27, 2016 | 06:24 PM
stewie01's Avatar
stewie01
1hr per liter!
Old Jan 27, 2016 | 07:13 PM
Spillage's Avatar
Spillage
Originally Posted by stewie01
1hr per liter!
Is that engine capacity, or beer consumed
Old Jan 27, 2016 | 07:35 PM
evilemokid94
I have seen the motor mounts on the k member and they seem alittle different, almost like a notched peice of metal in a sense. It's something I'll have to look into. First things first is finding the motor and tearing into it. Untill then I'm going to do what I can to mine.
