Low charging voltage. Alternator or Voltage Regulator?
Old Feb 1, 2016 | 07:41 PM
Moparite's Avatar
Moparite
You can full field it (Bypass the the pcm-regulator to give full output) and check the output in the truck. If the brushes are worn to the point they barley touch the commutator you may get an intermittent/low reading. But at 215K how much more life does it have anyway?
