Ground wires from firewall
Old Feb 29, 2016 | 01:17 AM
Double Oh Dodge's Avatar
Double Oh Dodge
Originally Posted by TNtech
Intake manifold, Water pump, radiator, heater core are not cast iron. Cast iron sealing surfaces can pit also, just not as fast and not as deep.
Well good thing I snipped it as close to the eyelet connector as I did then and kept the wire. I will be sure to cut it back a bit on each end,put new connectors on,and bolt it back in where it goes....I have enough crap to deal with.
I just didn't want a ground wire flying around loose in there when I noticed it and broke free of it's connector in the Head.
Old Mar 1, 2016 | 11:56 AM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
It's not a huge deal, but you will get more pitting over time. The point is that it CAN happen.
Old Oct 16, 2020 | 12:18 PM
Zach Kraemer's Avatar
Zach Kraemer
Originally Posted by studders
I wonder how long it is been off? I've had the heads replaced but that's been about 8 years ago. Wouldn't something not work right or throw a code. Haven't noticed anything unusual happening from it not being connected to something.
Have you figured out where all your grounds go? I recently did a engine swap. And now get a p1391 loss of cam or crank code. And trying to trace all my wiring. Because both engines ran when pulled.. i spun main bearing in my origional motor. And this new one came out of a buddies wrecked durango. But ran great. And now isnt running great lol so any help is appreciated
Old Oct 16, 2020 | 12:31 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Did you use the sensors off your original motor? Did you pull the crank sensor before you installed and removed the engines?
Old Oct 16, 2020 | 12:33 PM
Zach Kraemer
I did use my origional sensor that sits in the bell housing. But i used the durangos pick up(cam position) and the other one right out side next to distributor.
Old Oct 16, 2020 | 12:36 PM
Zach Kraemer
Do you know where the driver side head ground wire bolts to? I dont remember.. sorry for the stupid little questions. But im trying to rid of this p1391 code. And make this run like it did before the spun bearing.
Old Oct 16, 2020 | 03:10 PM
MoparFanatic21
I don't know if the sensors are different they might be. If you didn't pull the crank sensor before pulling the motor and installing it after the motor install it could be damaged. On my truck it bolts to the head and the firewall but it's not important. The engine has other grounds
Old Oct 17, 2020 | 10:25 AM
Moparite's Avatar
Moparite
You need to find out witch it is first. And the sensors have their own ground from the PCM not the engine.
Old Jun 22, 2021 | 12:00 AM
PDW's Avatar
PDW
AFAIK---From those three, One goes As mentioned, to the Backside of the [L] Head (bolt faces FW),
the Two on the FW itself lead to the A/T "Brain"(near the Hvac Condenser) and Main ECU (closer to the Batt)
I may be off a bit, but the Head Mounted on on mine broke off So to quiet concerns of Arcing it or Blowing vitals I snipped it off. As mentioned there are So many Ground Paths between the battery, chassis,Body, and engine Block it'self BESIDES one carried throughout the harnesses One ground cut out is equal to a single grain of sand at the beach.
I have the same three ground wires one is connected to the Head one connected to the block and the other one is just hanging there on the other side of the engine there is another ground wire connected from the Head to the firewall.
The one that is hanging there where does it go it's just kind of wrapped around the hose on the AC condenser does anybody have a picture of where to fasten the loose end?
Old Jun 22, 2021 | 12:01 AM
PDW's Avatar
PDW
