Ground wires from firewall
I have a 2008 Dodge Nitro SLT with a 3.7 L V6. Every lately I've had a lot of lights come up on my Dash. The traction control light flashed a couple days and then you check engine light came on for a couple days and then the oil light came on for a few minutes. There was no code found on the check engine light and the oil pump and oil pressure sensor is brand new with good oil in the oil pan. A friend of mine told me that it is a common problem with the Dodge for the ground wire to be faulty. Do you know of this situation? If so can you tell me where this ground wire is approximately on the Dodge Nitro?
well when I logged on there were post about Challengers Chargers Rams and Nitros but thank you for correcting me Karen! I'm glad somebody has so much time on their hands that they reply to someone needing help with no kind of help whatsoever. I will gladly send you a link to people who are hiring if you need something to do old man. Get a life or a hobby or a donkey in your mouth if you need some entertainment! Since you are no help to me disregard this post and move on geezer
