gas in fuel
Old Mar 1, 2016 | 02:11 AM
Miketal's Avatar
Miketal
Default gas in fuel
I put gas in my 01 dodge started it up ran about 3 minute then stalled I realize what I did and towed it home drained the tank what else should I do
Old Mar 1, 2016 | 07:53 AM
The War Wagon's Avatar
The War Wagon
Red face
CLEARLY it changed your Gen.2 Dodge, into a Gen. 1 Dodge!
That seems a LARGER part of the problem...
Old Mar 1, 2016 | 08:03 AM
One cannot simply assume your truck is diesel. Your post makes no sense. Gas IS fuel. So you put fuel in your fuel. Moving to the correct section.
Old Mar 1, 2016 | 08:24 AM
TSU_Delta_Chi's Avatar
TSU_Delta_Chi
Fill it with diesel and keep on trucking.
Old Mar 1, 2016 | 10:04 AM
Snowfan's Avatar
Snowfan
DO NOT TRY TO START YET.
Drain fuel filter AND REPLACE. Crack loose injectors and turn key without turning starter to pump out gas. Easy to smell and see when it goes to diesel only. Snug them up and start.
