Front Shock A-Post
Old Mar 1, 2016 | 04:04 PM
Kaldir's Avatar
Kaldir
Default Front Shock A-Post
Hey Guys,
I bought new shocks for the old girl, and I wanted to inquire about the best method to remove the front shocks. The 3 nuts / bolts for the a-post are rusted out so bad, that there is not really any teeth or a nut anymore. I was thinking of just grinding off the nut and then drilling a hole down through and adding a new bolt and nut.
Is this a good idea? Or do they sell something to replace the 3 bolts for that.
Thanks guys
Old Mar 1, 2016 | 04:25 PM
They are just nuts and bolts, nothing special about them. Of course, the dealership will want an arm and a leg for each one.... Just go the the hardware store and pick up some grade 5 nuts/bolts the appropriate size.
Old Mar 5, 2016 | 01:17 PM
stands2p's Avatar
stands2p
http://www.rockauto.com/info/11/AMG_..._TOP__ra_p.jpg that is what you need dont listen to that up^^^there its wrong.as you can see the bolts are attached to a ring that is flat and allows the spring to ride flat in its bucket.
