2000 Ram 1500 5.2L Runs rough cold
Ok so I just got this truck and when you first start it it runs really rough, especially under a load (going up a hill). Once it's warm, it actually runs pretty good. I have already replaces the idle air control valve because it has shown a code for that but without resolve. Any ideas? Fire away! Thanks in advance.
Try unplugging the pre-cat oxygen sensor to force the PCM to stay in open loop mode. If the rough running doesn't come along while the thing is unplugged, replace it. Use only a dealership part, Denso, or NTK. Any other is more likely than not to disagree with the PCM's slow feedback loop.
Also: Don't let the thing running well without that sensor fool you into thinking that you can just run without it. You can, true, but you won't like the result.
It's the other way around. If it doesn't run rough with the sensor unplugged, the sensor is bad. Oh, yeah: Expect a CEL and code for the sensor when it's unplugged. Just clear it later.
